demarko210
- Joined
- Jan 2, 2015
- 655
Last year I ran it on muffs and the impeller burned up as it needed changing and just I had just purchase the boat. I did all the fixes new pump kit with housing and pressure test lower unit and also installed new thermostats (143 degree).
Yesterday I tried to run my engine on muffs to test my NMEA2k engine gateway with Simrad IS35. Before I started the motor I primed the water separator with half seafoam and half gas. What I notice is after the engine started and ran for a bit, it never started peeing water. I ran my engine this time off of my freshwater washdown. I wanted to ask is this ok to run engine on muffs with freshwater washdown to ear muffs? IS that enough pressure coming through the pump?
After running for a bit I started to see little water start spitting out of the upper exhaust. I have attached a picture with pointers. Again after running for a bit I started to get a alarm sound. I could not tell what it was because the Gateway to 2k was not configured. The engine and reserve oil reservoirs are all full so I am under the assumption that the engine was letting me know it was going to overheat. I have read these 2.5l's take a while to pee and I could remove the thermostats and it should pee right away. Dont want to do that as it there for a reason. Nothing is blocking the passage ways I stuck a vacuum fitting to see if it would hold pressure it would not. Poppet valve maybe???
Here is a link to a video showing a different location where I saw water coming out of the mid section. This was just above the connection to the lower unit and mid section. Let me know thanks. Link here
