NYGiants
- Joined
- May 3, 2009
- 582
I have a 2003 johnson 2 stroke 25hp outboard. It has the stock prop and i use it to push a 14' heavy duty lund. (floor and such) i can max out around 23mph factoring the tide out, this is with 1 person at 140lbs. I dont have any problem planing and the trim is the second notch pin in the transom bracket. it is also tiller steer
1) Performance issue you are trying to correct. I feel like this isnt as fast as it should be, but not sure.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
I am not sure, but its the stock prop.
3) Current prop diameter and pitch (required). 10x13
4) Wide open throttle RPM and speed with an average load (very helpful) I'm not sure of the WOT rpm but the speed is at WOT. and average is load is around 350lbs person weight gear.
5) Engine/drive make, model, year, and HP
2003 Johnson 25 horsepower 2 stroke
6) Boat make model, year, length and weight 1988 lund (pro angler?) 14.6" and weighs aprox 440lbs
