'03 Chaparral 180SS Penta 3.0 GS & SX-M (2.18 gr) presentation & 1st major issue
Hello everyone!
Me and my wife recently bought this semi-project Chaparral a few days ago. I am going to post a few pictures as I clean it up, for now I'll just link the initial ones from the facebook ad. The story of her life after 2011 is that it sat for 7 years uncovered after a divorce, the previous owner bought it in 2017 and took it out a few times but not enough to justify the amount of money they had to spend on maintenance and fixing it up so they decided to sell her.
After we got her me and my wife were a bit too excited about owning our first boat so we decided to put it in the water as soon as we got home. It has issues starting, according to the previous owner it had a rebuilt carb put in in 2017 but it was never tuned up correctly so it needs someone to move the accelerator bracket just a tad to get it to stay running at idle and it also needs a nudge to keep it going those first few seconds after it's put in FWD or R. If it doesn't die immediately after it engages R or FWD then it is good to go. Even with someone helping while I was backing it up we still took a loooong time at the slip having to restart all the time as it was dying out as soon as it engaged R. Luckily there were 4 lanes at that place so we others were still able to get their boats in&out. Anyway, after it ran for awhile all was fine and I could get the rest of the crew in and we were moving. The motor ran fine, according to the runtime gauge it is at 87 hours. The trim and voltage gauges were not working and for some reason the RPM gauge showed an idle of 1500 to 2000 rpm which is incorrect. I think it definitely idles higher than it should but it's definitely not 2k. I'll come back to that gauge later.
As we were cruising along at about 25 to 27mph at around 3500 to 4000 rpm (according to the rpm gauge) against the receding tide I felt 3 jolts, each slowing us down considerably until the boat stopped after the 3rd one and the engine rpms went crazy (over 4500) while the shift handle was still in FWD. All of this happened in about 3 seconds. I immediately took it out of gear and put it in neutral, let the engine calm down, checked the depth gauge which at this point was fluctuating between 2ft and 8ft. It was previously showing values of 10 or higher and I was planning to turn around soon but I didn't get the chance to do it. After the motor went back to idle I tried engaging R, felt another thud, not as bad as the previous 3 ones. After that thud the motor started revving at 4000+ so I immediately backed off and put it in neutral. At this point any attempt to put in FWD or R yielded the same results, no movement from the prop at all, just the revving. I'm thinking I hit the bottom of the river because when we were trying to turn the boat back towards the slip we were able to see the bottom in some areas, it was less than 3ft under the water line. I thought I had trimmed up enough before all of this happened but I was nowhere near close to a safe level and because of the defective trim gauge I had no feedback on it.
After this we decided to call seatow since we were about 2 miles away from the slip but they quoted us 1000$ or more depending on the distance they had to travel from their dock. Our contract with them wasn't going to take effect until the next day so we were SOL on that one. Luckily about 30 minutes before it got dark, as we were paddling towards the slip two really nice guys in a small tracker boat saw us and towed us to the slip. It was dark by the time we got out of the water and had secured the boat to its trailer.
Now, the next day (Memorial Day) found me opening the shifter mechanism cover, checking the shift cable (it was misaligned but not by much) and the removing the cover to check on the shift clutch (sliding sleeve). With the link rod removed, shifting manually (before removing the selector unit) the prop would spin freely in FWD & R. After removing the selector unit and visually inspecting the shift dog and FWD&R gears I couldn't see any abnormal wear. Moving the clutch manually up and down as far as it would go didn't help engage the prop, it would still spin freely. I noticed that when I spin the prop there's no movement of the clutch itself, as far as I could tell from studying the schematics it is splined to the shaft going towards the lower unit. I'm thinking there might be a mechanical disconnect somewhere in the lower unit, maybe one of the splined sleeves or a gear or even a broken shaft. I messaged muc earlier today and he suggested I post this here. I was going to wait until the boat was in better shape to present it to all of you but I'm kinda stuck on this and before I pull the lower unit I wanted to see if anyone had any idea of what could cause this.
A few other things I forgot to include are:
-I drained the gear oil, it was dark but not frothy or filled with metal shavings. It had a few very small metallic looking pieces on the drain plug magnet but they were less than half a mm thick
-took the prop off and I can spin the shaft with the same results as when the prop is on, the cone clutch isn't moving when it's in the N position or when it is engaged up or down on its shaft.
-I didn't smell burnt rubber so I don't thing it's the engine coupler that went bad + if I try to spin the gears themselves I can't, they're solid because of engine compression (I think)
-stern drive is an SX-M, Prod no: 3868896, 2.18 GR @ 4202065414
-motor is a 03 Volvo penta 3.0 GS, I'll look at the serial when it stops raining and I can take the cover off the boat.
I would appreciate any pertinent advice. Initially I was going to buy all the tools to do a clutch repair like the user "nobama5555" did in his Youtube videos but I don't think it's my clutch that's bad. It doesn't look glazed or too worn.
I hope you all have a great day and thank you for reading!
Hello everyone!
