Hi,
I have a 2003 Merc. 150 EFI Salwater (Not optimax) outboard. When I shift FROM F or R TO Neutral I get a grinding noise. Shifting FROM N to F or R is normal. Lower Unit is free of water and metal. Thrust washer is correct. Motor otherwise runs fine. It's seems to be getting worse, to the point where I'm shutting the motor down while still in gear to avoid the grind. The factory (Merc.) told me it's a shift adjustment issue ?? The only thing different since the problem developed is swithing from an alum prop to SS. Can a heavier prop cause this ? Is the idle to High ? Something worse ??????
ANY advise would be very helpful. Thank you
