Ok so i took my boat out for a spin today and i had the motor wide open and let off and it starting dogging out and spitting and sputtering and what not...and id crack it back open and it would run fine...and i shut it off and i couldnt get it back started got home and hooked it up on a water hose and held the throttle wide open and it would start but as soon as i let the trottle down it will die and starting it with no trottle as i have to do all the time because you cant start it in gear it will not even crack open until i take the hood off and hold the trottle open then it will start eventually and as soon as i get it running and hook the gas line back up it dogs out and dies.but runs good when i take he fuel line back off again??...and its leaking a bunch of fuel mixture out down by the prop? is something stuck or whats going on anyone have any helpful ideas thanks
