'04 Angler 1700 SS prop performance
ASCTLC
Hi everyone,
Cool web site for boat owners!!! Especially for the brand specifics!
I could use some assistance with trying to figure out what kind of prop change, with a 2004 Johnson 115 HP 4 Stroke, will improve the performance of my boat and engine. I'm interested in a good compromise of top end speed and decent hole shot, not a primary focus on one or the other.
Because I am still learning I do not know the prop makers out there and their benefits. I'd say I'm not too afraid to buy a decent prop of good quality but with nothing to go on yet, I don't know if that's a $200 prop or a $500 prop (or am I kidding myself on prices? :eek: ).
In all my searching I see a lot of minor adjustments needed for most people but my situation appears to be a bit unique.
The problem are:
When I try to take off from a stop or very near stop, my prop ventilates pretty bad. I have to drop out of throttle to get it to hook up and rethrottle at a slow rate to keep it hooked up. I'm guessing if it'd just hook right up it'd come right out of the hole and on plane because it doesn't seem to do too bad now.
Same ventilation problems (blow out?) for pretty sharp turns.
Also the engine hits its rev limiter far too easy. I realize it's subjective but I'm quite a ways from full physical throttle position forward and hitting the rev limiter of the motor (~6300 rpms). Maybe 80% of full throttle physical range and it hits the rev limiter while cruising.
You're probably thinking "Prop Slip", right? Read on...
I've seen it mentioned that prop slip could be the problem but if I interpret correctly a common symptom of prop slip is the prop hooks back up and gains thrust when easing back on the throttle a little when cruising. Mine doesn't, it continues to push right up till the rev limiter starts and I'm doing about 32 mph.
The Antiventilation plate is just about dead even with the bottom of the boat. Maybe down below just a hair (1/4"?).
I have my suspicions the prop is just way too small and the engine has so much torque that it can't grab enough water and ventilates.
I have a 13 1/2 x 15 prop and there's only 1 prop smaller available and it's 13 1/2 x 13. This motor is good for up to a 14" diameter prop, so it looks like I have a decent selection of options.
Now the big question: Anyone in here have a very similar set up that can advise me on what prop is performing satisfactorily on yours? I understand the general rule of 1" pitch increase drops rpms about 200, but I'm so far over max rpms hitting the rev limiter that I can't get an idea on what size and pitch to consider.
The details:
Application: It's used strictly for fishing, not skiing or pulling tubes. Typically carry 1 - 3 people fishing.
Boat - 2004 Lund 17' Angler SS.
Motor: 2004 Johnson 115 HP 4 Stroke.
Prop: 5033322 - 13 1/2" x 15" Perfect shape, no scrapes.
I can't express just how much I appreciate your help on this!!!
Andy
Rancherlee
Re: '04 Angler 1700 SS prop performance
MY parents have a Lund with the same hull running the Suzuki DF115 (your johnson is a DF115 painted white with johnson stickers) and they have a 14x21 prop on theirs and it runs out at about 41mph ~ 5800rpm and has a pretty good hole shot.
Did yours come from the dealer with that prop (if so, SHAME on your dealer) The suzuki's have good torque and its definatly blowing out your prop with that small diameter AND pitch.
ASCTLC
I am the second owner so I cannot confirm that the prop is the one that came on the motor but at only 30 hours on the boat/engine when I bought it, I suspect so.
Thanks for the reply! I hope to see additional confirmation that the prop is just too small for this boat/engine combo.
Andy
woodchip
I have a 1700 Prosport with a 90 4s.My prop is a 13.25 x 17 but i'm at 3700 feet.You sould be running a 19 or 21 pitch prop I would think.Any good local prop shop should be able to steer you straight.
ASCTLC
Thanks Woodchip. I'm in Colorado Springs and there is no reputable prop shop local. Unfortunately, in the Springs, if you need something done right, you have to learn it all through research and do it yourself.
I use the boat typically around the 4500' elevation so I'd suspect I'd want to err on the smaller of 2 pitch dimensions if having to choose one over the other?
Andy
Ron G
I agree your running way to low of pitch,see if you can borrow a 21 and get some wot numbers from it.then well have a good base line to go by.but you hitting the limiter and not even wot is not good at all.
ASCTLC
I spoke with Lund today and he said I might consider starting with an 18 pitch. Couldn't/wouldn't answer the diameter question. I guess I could start with the 13 1/2" dia. Just a little leary because I am *so* far over the rev limiter that a 300 rpm drop going to an 18 pitch doesn't sound right. But what do I know, that's why I'm on here asking.
I suspect my use at 4500' elevation will require 2" pitch reduction? Or only 1" pitch reduction to make up for my higher altitude? Anyone have a rule of thumb on how much pitch reduction is needed for altitude affects?
Am also considering a stainless 4 blade since a couple mph top end doesn't mean much to me. Thinking after writing the original request for help, I guess I'd rather have better transition to planing and cornering than a couple extra mph at the top end.
As you can see, there are so many specs being changed here (from a 3 blade aluminum 13 1/2" x 15p) it's hard to understand where to start. The nearest water is about 1 hour away to test so trying to get closer is my quest. I seriously doubt I'll find someplace to "borrow" a prop so ponying up the dough is best done only once.
Then once the specs are figured, then it comes down to brand and the affects that might have. :redface:
Thanks,
Andy
