Sirrobin53
- Joined
- Mar 13, 2012
- 189
Well, having the same issue with this missing engine at wot. Idles well with just a little shaking which, what I have read, is common to the 3 cylinder engines. I have rebuilt the fuel pump, gone through the carburetors for the 3rd time, changed the coils, rectifier /regulator, plugs, trigger and the link/sync performed 5 times and verified 6. Timing is set at 19°BTDC at WOT. This was done in the shop, hot battery, charger on and plugs out cranking.
. The trigger was changed because the potting was cracked and it was sticking on the boss and not turning. The regulator / rectifier was changed because it was not charging and the wires were melted at the regulator and stator connections. It now charges @ 14.2v.
The problem is from 1/4 throttle to WOT. Seems to be missing when pegged at WOT. Let off to 3/4 throttle and missing quits. Ease throttle back in slowly and after 3 or 4 tries can get it to WOT.
Pumping the primer bulb makes no difference. All filters changed, new fuel lines.
IDK. I was hoping for a trouble free boating season. So much for that.
Any ideas?
I apologize for the long winded post.
Any ideas?
