05 evinrude 150 di
nemo956
hello everyone this my first time here. need help I've got an 05 evinrude di e150plfsoc having trouble starting the motor was taken off to repaint boat and new floor after it was put back on started having problems starting it fires right up but dies maybe after 10 or 15 times it will stay on. if you throttle up a bit it will start quicker maybe after 4 or 5 times it does it cold or after running awhile. you turn it off 1 minuite later same problem once in awhile you fish about an hour and turn the key fire right up first time I'd appreciate any help
Bosunsmate
Re: 05 evinrude 150 di
Hi,
Does it run ok once started, can you get up to full speed and stay at full speed?
nemo956
yes once it starts it'll run like a raped ape about 5 miunites thru the no wake zone and then to my fishing spot no misses or hesitations i'll run maybe 4500 rpms
