'05 Glastron SX 195 Side Exit Exhaust
csharp
I'm looking to install side exit exhaust on my '05 SX 195 with a Volvo Penta 5.0. Has anyone ever done/seen this install? I have a couple pictures of a guy who had this system and there are some youtube videos floating around - same make/model engine size etc. I'd like to use Corsa side exit components but forego the full captain's call system at this time at just run straight pipes. Any thoughts?
wca_tim
Re: '05 Glastron SX 195 Side Exit Exhaust
I hate the way they sound... and when they're loud so do a lot of the people on the bank....
Mkos1980
From what I hear, you have to have at least a balance tube with the side exhaust. Basically if your on the side of the boat all your hearing is a 4 banger basically. I would eather invest in that or straight out back under a swimplatform or something.
Coors
Stern thru hull, with down pipes. Bondo has a thread in here.
csharp
Thanks for the useful information Tim. I'll be sure to keep that valuable insight in mind when I make my final decision. I'm glad I can count on this forum for clear and concise technical responses to my technical questions.
Sincerely,
Sarcasm
D
DJ
Guest
I have side exhausts on a 26' Crownline (7.4L MPI-B3).
Mine were factory installed. I suspect they put them out the side because of the transom design.
They sound fine, particularly at idle. I run them closed the majority of the time. I have a on dash switch that allows me to run them open, or closed. My choice. You can just see them, in this pic.
dcg9381
Nice looking boat.
I like the way they look also, but have to say that I saw a boat (23+ ft) come by in a cove this weekend and it sounded like a 4 cylinder on slow cruise... I really did a double take.. Kinda odd.. I think most people won't notice though.
The other issue with thru-hull is that if you're spewing water down the side of the boat, this fuel/water mix LOVES to stain the gelcoat. I've got thru-hull on mine and I absolutely detest cleaning it... It's the first thing I've got to do when the boat comes out of the water, unless I want two streaks down the back of the boat.
Coors
Get some that extend out 4".
