05 Malibu problem
Caveman Charlie
My sister in law has a 05 Malibu Maxx. While driving yesterday is started beeping/dinging at her and the radio says DAB on it. It seems to still run OK and she is going to take it to work tomorrow but, we were just wondering what this is all about??:confused:
Thanks for any help you can give.
jimr
Re: 05 Malibu problem
the owners manual should say what it means usually when they display something like that. if you find out let us know
cbac
That has to do with the XM radio Charlie, it's Digital Audio Broadcast or something to that effect. Her sat antennae may have a problem or something to that effect.
Caveman Charlie
Thanks she doesn't have sat radio but, it originally did. It has been very cold and we think that may have screw it up somehow.
Bob_VT
Everything is done via the radio on a Malibu. Language, oil life reset, units from KPH to MPH....... door light options lock options....
It is all listed in the owners manual. Here is a C & P I found
A driver information center works through the stereo display, providing gas mileage, distance to empty, average speed, and other information (not compass heading) underneath the radio station or CD status. You can also program various options through clearly labelled buttons by the stereo, including automatic lock behavior, oil status (so you don't change the oil long before it's actually needed), English/metric dashboard displays (so the speedometer only needs one set of numbers and is easy to read in the US and in Canada), and other features. All can be set up via easily pushed and well labelled buttons by either the driver or the passenger, and since the status display is in the middle of the panel, pretty much anyone in the car can read it - a much better idea than having it right in front of the driver so nobody else can read it. There is also an outside temperature display, but to get to it, you have to push the stereo's information button (not the info center's information button!) four times. The first pushes get you the artist and track if you're listening to XM Radio. Now that most people use the remote control, it is helpful that the system will also warn you when your battery is low!
Caveman Charlie
I don't think she has a remote control. But, maybe she does and she just stashed it somewhere. She does use the CD player. She listens to books on CD's that she checks out form the local library. She also use the FM radio. The rest of that stuff is things she didn't want but, they force you to take it because it comes with the car.
