05 Yamaha F115 Oil blow-by cracked pistons
Millcreek1
05 F115 oil blow-by problem:
Upon further investigation,
#2 & #3 pistons were cracked causing the oil blow-by problem.
I see the part # have changed, did they change or update the pistons?
Has this been a problem w/ the f115, if not what caused it.
Should I think about trading it in?
Thanks guys
robert graham
Re: 05 Yamaha F115 Oil blow-by cracked pistons
sounds like carbon build up on and behind the piston rings and grooves. after the rebuild, start using Yamaha Ringfree all the time. Good Luck!
Silvertip
It's a four stroke. Carbon build-up should be a non-issue.
Millcreek1
Where is RODBOLT ON THIS ONE?
No just kidding, runs like a champ, like brand new, (waiting on that next piston to crack),(Hopefully not?)
See ya on the next round!
