06 115 merc lift pump
Riverguy1
I have a 06 merc 115hp and I'm trying to find out if the lift pump is rebuildable it's a 880890t1 and I cant find anything online about it only 2-300$ for a new one
tommarvin
Ensign
Are you talking about the Tilt and trim motor,that makes the motor tilt up and down?
What exactly wont your T&T motor not do,theres a few thing that can go wrong with it.could be electrical, you should check the fuses to start, then theres relays that stop working and more..
Are you sure the motor is full of ATF fluid,top it up,to be sure.
I dont know if theres a rebuild kit,
We have twin 2002 four stroke EFI, Question do you have to say four stroke if you say EFI ?
Anyway, we can get our T&T motor/pump for about $125.00, the point you need to expand your search, search harder.
Riverguy1
Sorry I'm talking about the low pressure fuel pump aka lift pump I see a ton of rebuild kits for other fuel pumps but not for mine I was hoping someone might now more about it because all I can find is the diaphragm for it and they want 100$ for it but it's not exactly a rebuild kit just the diaphragm
