Good evening I have an 06 Suzuki DF50, engine was running but had a misfire, checked plugs and coils they were fine, checked injectors and had an injector that wasn’t firing. I replaced all 3 injectors and all 3 spark plugs. Went to start up engine and it will only crank. I have checked spark and I have spark on all 3 plugs, I am getting fuel to injectors, engine won’t even fire up with brake cleaner. I have hooked to engine with the Suzuki diagnostics software, kill switch is working as it should, neutral safety is working as it should, my fuel reading are where they need to be and ignition timing is at 7 degrees BTDC. I have checked my CPS and Ohmed it out, sensor it within spec, I checked the ohm reading on the camshaft position signal and was getting 25 ohms. I’m at a loss on where to go from here, can someone give me some guidance please.
