skidooseadoo83
- Joined
- Apr 5, 2012
- 32
So i did a major overhaul on my 07 VX deluxe, and here it is for anyone maybe contemplating a project like this. It is a big undertaking but can be done. This was my first experience with fiberglass and it didnt go too bad, definitely learned a lot. This thing was trashed when i bought it, and i dealt the finishing blows. 30 miles up a river in the middle of no where Alaska i had to drill a hole through my drive shaft coupler and drive shaft to stick a bolt through it so i could get home, it totally stripped out the threads on the aluminum coupler when i sucked a rock. Also, the hull was leaking badly. Things needed replaced/fixed- drive shaft coupler, drive shaft, bearings, impeller, sponson (hole in it) intake grate (missing a bar) hull needs re-fiber glassed, broken mirrors, stator housing, impeller housing trashed, missing rear trim. Upgrades- aftermarket impeller, scoop pump intake, pump shoe seal kit, aftermarket air intake filter, aftermarket adjustable sponsons, remove water box and install straight pipe exhaust, replace mirrors with cleats, and speakers system. This all took me about a month.
Started with the easy stuff, sponsons first.
cant tell from teh outside its totally f'ed inside.
Chewed impeller and stator fins.
