Does anyone know what size and where to get a replacement skeg for this motor it is the 3 cyl 115 optimax.
I do not want the skeg guard thing you bolt on I want the correct aluminum skeg that needs to be welded on.
Also does anyone know if this can be done with the techno weld aluminium sticks that use low heat from a regular torch. You can see them on youtube.
