08 bayliner 3.0
Jakem
Working on this boat for a friend and the fuel pump wasn't working so we replaced it..same issue...there is no obstructions and filters new...now is there a rod the pump shaft rides on. From what I can see and feel it seems just to ride the cam lobe...any suggestions
No, the inline motor fuel pump rides directly on a cam lobe
Test from a portable tank. You could have pickup issues
Scott06
Also check anti siphon valve on top of fuel tank they can get stuck
Jakem
I got her pumping however the carb is now in question. Hardly any shot of gas so..
Rebuild time
Scott06
Rebuild time
There may be a stone type element in carb inlet might check that first of fuel contamination is an issue.
3.0 has a fuel filter on bowl on btm of pump
