1/4" - 3/8" Aluminum Plating in Corpus Christi ?????
cvlngineer
Does anyone in the Corpus Christi area have any ideas as to where I might find a couple of pieces (28" x 15" and 28" x 7") to use as transom braces?<br /><br />Thanks,<br />cvlngineer
ob
Re: 1/4" - 3/8" Aluminum Plating in Corpus Christi ?????
Here's two supply houses you can call and give dimensions to if you are not equipped to cut.<br />Texas Steel<br />7414 Leopard st.<br />361-289-1522<br /><br />Industrial Piping and Steel<br />333 45th street<br />361-884-1677<br /><br />One of the moderators may move this to the boat projects forums ,so if its gone later look for it there.
cvlngineer
ob,<br /><br />Thanks for the information. I will give them a call.<br /><br />cvlngineer
