Re: 1/4" plywood strong enough?
structurally wise I think it might be strong enough (borderline). A couple of things to think about. first, trying to make a shell out of 1/4" that will be stiff enough so that the panels don't appear to be bowed or have a wave in them is going to be tricky. The one pictured has nice crisp lines and I don't know that you'll be able to get that same appearance with such lightweight plywood. Once the glass is layed up it will be stiff, but until then the layup is going to be tricky and the fairing will be tedious. I would consider going up to 3/8".
Also, I would personally look at a heavier glass layup. For example on each side of this enclosure I would layup in this order : 1st layer CSM 1.5oz, 2nd layer 1708 biax then 2 layers csm 1.5oz each. If all these weights are added up inside and out you're looking at roughly 45oz of glass (22.5 each side). Also, I would consider using poly resin rather than epoxy. For cost, but also you'll be able to use standard csm rather than epoxy compatible csm; not a big deal, but probably easier to find on the "big island". Just my opinion... A couple of other Q's, what kind of plywood and how would you finish the enclosure (paint, gel, etc)
