Re: 1.5 amp onboard charger
You need to run the current use numbers like I did for the troller. A single small light (like an internal compartment light) will draw about 1/2 amp. If you have more than one, add them up. Spotlights can draw a lot of power. Look at the label to determine how much. If the spotlight drews 3 amps (again just an example) and you ran it for one hour you would need to have the maintainer on for over 2 hours. To make this simpler, for every 1-1/2 amp of power you use in one hour, the maintainer must be on for one hour.
