hi, i have been having problems with my battery staying fully charged. i checked my rectifier and when i checked across the red to yellow, meter readings were 0 for both directions on both yellow to red checks.meter readings for yellow to ground were correct.
now the hard part. when i look up the part i get 193-4204. the picture shows a much larger 4 wire rectifier. i currently have the smaller triangular shaped 3 wire rectifier. the hole pattern doesn't look like it will bolt on were mine is mounted. it appears to have 6 bolts were mine has 2. did someone install the incorrect rectifer? at this point i am very confused. i don't want to spend almost $100. on a part i can't use or return. any help would be appreciated.
thanks.
thanks.
