Re: 10 hour maintainence
it was not checked correctly then.<br /> shutters fully closed does not mean shutters at idle speed. the correct way is by fully closing the shutter, two ways to do this, one starts with the link and sync and includes setting/checking the TPS and the other will get you by for strictly the oil pump.<br /> at idle the idle speed screw on the throttle body assy actually holds the shutters open slightly.<br /> best way for strictly checking the pump arm to stopper clearence is by unclipping the lower two shutters on the stbd side then check the arm clearence. there is no WOT setting of the arm. the correct way is by starting with the shutter sync ,then to the oil pump arm check and ends with setting the TPS with the shutter fully closed, .5v plus or minus .02v, then adjusting the idle stop screw until the TPS voltage is about .01V higher than the setting at fully closed. fully closed is NOT idle setting.<br /> attempting to adjust idle RPM on an HPDI while running is futile at best and may create more issues than if the correct procedure was first used. there are several tech bullitens out on setting the TPS on HPDI. ask your dealer for them or for a copy of page 2-33 of the 05 marine tech guide.
