hans jensen
- Joined
- Aug 27, 2007
- 19
I have a 1999 Mercury 250 HP EFI on a 23' wellcraft walkaround. The previous owner had a boat mounted fuel/water separator (23 micron) that leads to the fuel pump and then from the fuel pump to the motor mounted (under cowl) fuel water separator (28 micron).
My question is, could this (2 filters) cause too much strain on the fuel pump?
Should I replace the boat mounted 23 micron filter with a 10 micron? I can't get the motor mounted filter in a 10 micron size so if I need a 10 micron filter it will have to be mounted in the boat.
