Re: 10 QTS of Oil ,Dip Stick Position???
Yes Sir! - it is installed--3 to 4 Inches above the bilge--but do have to move the bilge pump forward--I had to go bigger to clear the Windage Tray (4 1/4 deep in front ) and it is 8 1/4" deep. I went with a Melling 55-HV High Volume oil pump (70psi) and did not want to suck it dry during WOT runs. This pan I got from a local speed shop for $80 vs a standard Mercruiser pan for a lot more$$.
The motor is a Mild Tune with a RV cam , Flat top Pistons and a few extras.
