105hp Outboard Spark Plug gap size?
Faerbairn
105hp Chrysler Outboard
Model 1057HF
Serial # 4770
I believe made somewhere between 1975 - 1977.
Can anyone please confirm the correct spark plug gap for my outboard? Is it .030?
Also, the firing order? Is it 1,3,2,4?
Thank you.
Frank Acampora
Re: 105hp Outboard Spark Plug gap size?
Do not use bent electrode plugs in that engine. The correct plug is a Champion UL18V or L20V. NGK BUH or BUHW.
These are surface gap plugs and there is no gap to set.
Use of a bent electrode plug may result in melting holes in the piston crowns.
I believe your firing order is correct at 1324.
Faerbairn
Thank you very much Frank!
