10hp Chipper/Shredder
SS MAYFLOAT
I purchased one of these from Home Depot that was a reconditioned one. They took a hundred off the price of a new one.<br /><br />Took down a medium sized maple tree from a residence and moved all the wood and branches to my property. <br /><br />The chipper did impress me on how well it was mulching up the small limbs. I almost had everything done when it bogged down and quit. I opened up the outlet shoot to find the deflector place bent out of shape. Then I noticed a piece of wood about an inch in diameter caught between the shroud and the cutter. As the cutter rolled this piece around the shroud, it pushed out on the housing breaking the intake housing. When I first looked at the intake housing it looked like it was made of pot metal. Then after a day or two I took it to the repair shop.<br /><br />The part I thought was pot metal was plastic. The man at the shop said it was under warranty and he would fix it and send the bill to Home Depot. He then went on to say that it will happen again. He has fixed several of these units in the last year. It is a common thing to break. Other than that, it is a good machine he says. <br /><br />So I told him after the warrnaty is expired, I'm going to fabricate one out of metal. He said that I should do it now because he knows that part is going to break again.<br /><br />I just thought I would pass this on to those that maybe thinking of purchasing one. It is the style that has a intake for branches and then it has another intake for leaves and small twigs. It is the shoot that takes the leaves that is made of plastic that breaks. <br /><br />It is almost like using plastic gears in a outdrive! It won't work!
JB
Re: 10hp Chipper/Shredder
What make and model, SS?
jimr
I have a few year old Troy Bilt 10hp chipper that was given to me needing an engine and I love it. if you can get it in the chute it will chip it but you can overload it through the shredder port and burn up the belt. make sure to keep the blade sharp and it will work alot better.
ndemge
Now why don't they do a recall/service bullitian?... maybe make the part and make it available to the service techs, cause they KNOW it's a bad design.
TELMANMN
If it is new were the parts made in the USA? <br /> I have an mtd 8hp for 9 years and is going strong. No plastic parts internally. I have got it jammed a few times but no serious damage.<br /> I am always carefull not to feed too big of a branch but have a few times fed something a little too large. <br /> Depending on brand where were the parts made and where assembled? <br /> I have bought tools recently that have a "life time guarrantee" that were made in china. They state they are "chrome vanadium" and they are rusting sitting in the house(where the AC and Heat are always on. This reminds me of the older J.A.Pan co. tools. The younger people do not remember the quality or lack of. The only reason <br />they are still around is because the buisness people in the US) allowed them(they were going to invest and put you out of work.)<br /> Keep complaining and keep buying this crap because your children and grand childern will be working for these people at slave wages. <br /> GET USE TO THIS!!!!!
SS MAYFLOAT
Well, its been 2 weeks and no word on my chipper. Meanwhile my brush pile is getting higher and higher. Guess I should have spent another several thousand and got the industrial chipper....Yeah, right... :(
