10hp question
tjandrews
At a guess, all other things being equal (same boat, trim, load, etc.), which would likely be faster, a '54 10HP Johnson with a replacement 9x7 prop, or a '58 Evinrude 10HP with the original 8.25x8 prop?
Just curious...
ondarvr
It all depends on the boat, with a heavy boat the 7" prop might be better, a lighter boat the 8"
jimmbo
If one of the props lets the engine run at the RPM where it is making it's best power, it will produce the highest speed, the other one will have the engine either above or below the power peak and the boat will run slower. However the holeshot may be faster or slower depending on which direction the pitch of the nonoptimal prop went
MH Hawker
i run a 7 p pushing a 20 ft pontoon on a 10 hp lake at 5400 to 5800 rpm at 8 to 10 mph
