I have a 89 110hp evinrude with vro. I found how to convert it to pre mix. Everything went well, ran good. the other night i noticed the fuel pump side of the vro pump was leaking fuel when trying to prime it. It looks like someone tried to epoxy it. The guy i bought it from told me it had a fuel leak. When i checked it out all i noticed was that fuel was coming out of the carbs. Stuck floats. I've been using it with no problem. Wasnt until last night i noticed when priming it that it had a leak. My question is, i read on here that you could convert it to a non vro style fuel pump. I looked at my motor and it has the screw holes and a hole for the pulse that is plugged off. Someone told me that if i looked up my motor and it offered a regular fuel pump that, that was the one i should use. I guess some commercial grade ones didnt come with vro. I am having trouble finding the right part numbers. Does anyone know how to do this or what pump i should use. Where the lines would run?? thanks for any info.
