Hello, I am new to the outboard world (plenty of years as a car mechanic) and have an issue with my 2012 115HP 4stroke EFI Merc overheating. Just bought the boat this year and all was well until about a month ago. I got an alarm and the engine pulled power. Earlier in the day I got caught up a bit on a sand bar but was able to push through. Was able to shut it down, then continue at moderate speed back to the dock. Looked at the tell tale and it was spitting, but not a steady stream. So I pulled the boat and replaced the impeller. From that time on I had a steady stream.
Put the boat back in the water and was running about. high speed for 5-10min, then no wake. When going back WOT, the alarm hit again and pulled power. Again, limped it back to the dock. Purchased a new thermostat and Vessel View mobile. Took it out with a mixture of high speed and no-wake without any issues. Water temp looked good.
Then today (the next time out), Once again, high speed no issue, then no-wake, then high speed again and the alarm. This time I had vessel view up to confirm it is a water temp. Temp was approaching 200F. Quickly dropped back down at idle. Opened it up again and it hit the alarm. Let it cool down and wanted to make one more pull with the motor trimmed down to see if that helped and it did not.
One thing I sort of notice after the alarm (after returning to idle), when I look back at the tell tale, I see some visible exhaust fumes near the water line that dissipate (not sure if that is relevant at all, but wanted to provide all info).
Does anyone have a diagram of the coolant flow for this motor? I plan on pulling the boat out of the water either later this week or early next week depending on weather. Any ideas as to what I should be looking for? I plan on doing a flush and seeing if I can get access to small passages such as the fuel cooler. Without an understanding of the coolant flow path, not sure how much a strong tell tale helps in this scenario.
Thanks in advance.
Daryl
Thanks in advance.
Daryl
