115hp tilt n trim broken hydro lines question
wmgraphics
I have a 1973 115hp and rebuild went great running nice. Now for the trim/tilt. Motor seems to be OK but one of the hydro lines is busted. Can I replace these with flexible lines? Does someone know where I can buy A replacement? Can it be welded? Open to all options and suggestions. Thanks! Mike.
crb478
Re: 115hp tilt n trim broken hydro lines question
If it is the lines themselves you can use steel brake lines with the flaired fittings. You can also use the flexable ones if you want. The low pressure flexable line has a fitting that is hard to locate, if it is that line you will probably need a hydraulic shop to cut the end off and make a new line with the old end.
