Re: 12 ft aluminiun boat Hp rating
The type of boat makes a difference, flat or v bottom or mod v. Ive got a Valco U12 which had a 7.5 2 stroke, replaced it with a 20hp 4 stroke and the difference is night and day! Gets on plane right away and goes more than twice as fast. A 12ft flat bottom will probably not handle a 20hp 4 stroke cause of the extra weight and low sides but a V bottom always runs a deeper draft and can afford the extra weight. Your beam (boat width at back) is also a factor, mine is 65 inches. If its a flat bottom go with a slightly more hp engine, if its a v bottom go with the 20 and kick some a**. By the way, most new motors 15-20hp the only difference is in the carb, weight and everything else is the same. So if you like the 15 you might as well go with the 20.
