12" radial or 12" bias ply tire which one would be better for highway towing?
Bob427
in my last post i was looking at getting new carlisle bias ply tires
just found out they make 12" radials
i tow my boat 50 miles one way mostly highway
should i buy carlisle radials instead?
boat is a 16' starcraft with a 70hp evinrude and a 8hp johnson kicker total wieght about 1800 pounds
was wieghted a 1504 with a 40hp mariner when i first got it
current tires are 4.80x12 carlisle load c's
thanks Bob
rbh
Re: 12" radial or 12" bias ply tire which one would be better for highway towing?
Radials are far far better, sidewalls much stronger.
EddiePetty
.....and far less rolling resistance and thus less heat build-up!!
Go RADIALS !!!
Titanium48
Another reason to go with the radials: Most ST145R12 radials are load range D and rated for 1220 lb @ 65 psi, while the bias 4.8-12 LRC are rated for 990 lb at 90 psi. You get to run a lower pressure to soften the ride for your boat and still get a higher load rating. If you still want to go with bias, get the 5.3-12 LRC (1050 lb @ 80 psi).
H20Rat
there really is NO reason to run bias, other than cost... Radials are better in every way.
'78 Crusader
I made the mistake of running bias ply on my tandem trailer...won't go that route again. I'll drop the extra coin and go radial this time.
Bob427
well i decided to buy 2 new st145r12 carlisle radials with rims free mounting and shipping for 189.99
hope these last for awhile
thanks for the input
Bob
