Dave-R
- Joined
- Mar 18, 2008
- 441
The engine I have is a 2001 4.3GL Carb engine. I tried hooking up the 12 volt source of the meter to the purple wire on the starter solenoid. The meter worked when I turned on the key, but the engine would not shut off. In a panic, I pulled the coil wire off. At 67 years and a heart condition, I was lucky to be writing this. I still do not understand why that happened, but when I removed the meter hot wire from starter everything works . My question is this. Is the hot wire to the electric choke
always hot when the key is on, or when the engine is running? I know the choke takes about a minute to open fully, but what shuts the choke off. And can I use it for a power supply. Thanks Dave-R
