rich_kildow
- Joined
- Apr 21, 2010
- 26
I found the little piece that goes inside the drain plug and it is mangled. Looks like whoever had it apart last wasn't careful with it, and I think it was sitting just right so that it worked properly. There is no way to get that to work.
Now the question. Is there a source for parts for the valve body for this motor ('90 120hp Force), or do I need to replace the whole valve body. If the latter is the case, am I better off spending the extra $150 or so and getting the entire pump/valve body/ reservoir assembly? Thanks,
Rich
Rich
