125 hp 1989 force plugs
my55
the plugs that are in my force are bu8h ngk the problem i have is when running for awile at hige speed it dies down and loses power but if you shut it down or clean the lower plug it works great again i have the blue boxes on it <br />can you help me <br />and how much water is susposed to flow out of the outlet?<br />and only the 2 bottom plugs get fowled or at least not as clean as the top 2 <br />what is it?<br />i checked the carbs they are clean.<br />the fuel filter is clean .<br />mixed 50:1<br />starts right up<br />help me please<br /><br />------------------<br />mike
clanton
Re: 125 hp 1989 force plugs
Jet size 1989 model C top carb .101 bottom.094<br />1989 model D and E top carb .098 bottom .096 . When it begins to lose power have someone pump primer bulb, if it picks back up, fuel problem. May be power pack getting overheat, cools down when you shutdown. The 87/89 have problem of spark jumping from coil to block, look on block close to coil for burnt spot. Run at night cover off you can see spark.
sony2001
The equivalence in Champion is L76V according to my repair bill. I didn't have problems with my BUHX. But I hear a crisper combustion with the Champions. Try 2 Champs on the bottom cylinders and make the comparision before changing electrics.
