125HP and 85HP Force Motor
Horse4190
Can anyone let me know if the lower unit for a 125HP Force Outboard Motor will be same or can fit to a 85HP Force Motor? Thanks
Jiggz
Most likely yes especially if they are of the same year and length. And what is even great is that the 85 LU has a better gear ratio giving you better hole shot.
jerryjerry05
You'll probably have to change the prop.
Like Jiggz said the gear ratio is different.
Being as the 85 is going on a 125 it won't perform as well as the other way around.
Horse4190
Need help. I am buying a Lower Unit for my 85HP - 1989 Force model. Will the 90HP 1992 Force will fit to my 85HP Force? Also, when it says 25" shaft - is this the measurement of where the propeller is connected? Appreciate your help. Thanks
