wilkin250r
- Joined
- Feb 9, 2003
- 570
I've got a 1988 Force 125, but it actually looks like it was possibly pieced together from several Force motors.<br /><br />With a little starting fluid, I can get it to start. Once it starts, I can keep it running as long as I keep the RPMs up, but if it drops below 1200 rpms, it will die.<br /><br />I've tried the obvious idle adjustment screw, i've tried everything from 3/4 turn to 2 1/2 turns, the result is the same. It won't idle.<br /><br />The compression is a solid 135 on each cylinder, the reeds look good, the only thing that seems to help is the timing. If I advance the timing to full advance, it will almost idle. Obviously this isn't the correct mode of operation, but it's the only thing that seems to have a positive effect.<br /><br />Any suggestions on what my problem could be?
