Planning on doing some rewiring in a 1988 Nitro Fish n Ski I just bought.
The wire that is there looks to be in pretty good shape and everything worked when I bought it so I'm not going to completely rewire the boat but instead I plan to use what is there. It was just all connected to the batt and I can't tell what wire goes to what.
Another problem is that there seems to be a lot of wire there that is not needed or connected to anything. (looks like this boat has gone through several transformations and bits n pieces were added and removed but all the wiring was left behind)
So question 1: what is what is the best method to identify the wires that are not needed or connected to anything?
Question 2: once I get all the old unnecessary wire out, is there an easy (read cheap) method to trace what's left back to the component without having to physically remove all the wire? some of which I don't think I can get to anyway...
Also, I did not see any kind of fuse panel anywhere so I bought a Blue Sea 5026 ST blade fuse block to install. Is that sufficient for a simple rewire? I think I'm going to have one "house" battery for all the components and one for cranking that will have only the motor and tilt attached.
So am I in the ballpark here or is there a better way. I would like to keep this as simple as possible.
Thanks!
Thanks!
