130 Yamaha Alarm Going off
swann1
I have a 2003 130hp 2 stroke Yamaha outboard, 130TLRA, 6L1, L, 314664, at higher rpms intermittently the buzzer sounds and slows the motor, the temp led is not coming on and the oil leds are not blinking (both of which I have dealt with before,new impeller, cleaned up oil reservoir). My mechanic said it must be a voltage issue and replaced a fuse holder and cleaned up some connections, it did not help. How can I troubleshoot this? How can I disable the voltage alarm to make sure this is the problem?
