Hi everyone last year I bought my first boat a sea ray 175 with a 135 Mercury v6 outboard on I’ve taken the boat out a few times now and every time it hasn’t revved in drive past 2,000 rpm but neutral and reverse revs freely . So far I’ve noticed the high speed Idle sensor had a burn mark on so replaced it , after this was change I’ve checked the flywheel and noticed the flywheel stator and triger had gone so I’ve replaced these and it’s still not running I’ve then checked the fuel lines and noticed the small t on the middle carb is blocked is this critical or can I use a straight connector to join the pipes ? Thanks
