14/11 prop replacing a 14/21?
Dyna
yep you read the correctly. I had my original prop sent out for repair awhile back & threw on a new 14/21 I had purchased. Well after 3 months I hit a sandbar & tore that prop up pretty good. replaced it with my newly rebuilt prop & the boat wouldnt move above a trolling speed. Couldnt figure it out, thought maybe I tore something up in the drive when i hit the sandbar.<br /><br />was checking out both props today & discovered the marina didnt give me back my original prop which was a 14/21 with no markings. the one they replaced it with is a 14/11 with very clear factory markings on the hub.<br /><br />No wonder I couldnt get my boat to move very well after I swapped props. :rolleyes: Now I just need to convince the marina they screwed up.
MrBill
Re: 14/11 prop replacing a 14/21?
Tell them you don't own a trolling motor...and ask kind of application a 14/11 would be used on...a 60 HP outboard no less
Dyna
Well right now they cant find my prop. The marina is doing a little more looking around & if they cant locate it they are giving me one they have sitting at the shop. No big deal as of right now since I have no time to take the boat out anyways.
