14.25x19 VS 14.0x21 3 bladed aluminum Prop ?
rex979
I just purchased a used boat, 1997 Glastron SE 170 bowrider with a 1997 Johnson 130 outboard and it came with 2 different, 3 bladed aluminum props. 14.25x19 and 14.0x21. Which one is geared lower for more pulling power vs top end speed ? I assume the 19 pitch but not sure how the bigger diameter fits into the picture. I haven't had a chance to try them yet so don't know what the difference in RPM might be. Thanks
jimmbo
The 19 will have better hole Shot. There will be about 400 rpms difference between the Props. I doubt there will be more than 1 MPH difference between the two. Do you know the WOT range for your engine?
rex979
Thanks for the reply.
The 1997 Johnson 130 (as per the manual) is rated for maximum horsepower at 5500 RPM and is supposed to be run between 5000 and 6000 RPM WOT. I have not run the boat yet, still ice on the lake so can't comment on what it does right now. I understand the lower pitch will give me more advantage out of the hole, but mainly I was curious to find out which has more of an effect, the pitch or the diameter of the prop. As per the Glastron manual this boat was tested to run 46 MPH WOT with a 14.25 x 21 prop.( I have a 14x21 )
jimmbo
This comes up often, but I always tell people to let the Prop Engineers worry about the Dia, in a lot of Prop lines the Dia gets smaller as the Pitch goes up. Probably due to the fact that lighter faster boats will utilize the Higher Pitch Props and moving a slightly smaller volume of water at a higher speed is beneficial for higher Top Speed, even if slip is a bit higher.
rex979
Great. Thank you for the responses. Now just have to wait for some clear water to try it.
Cheers
Sea Rider
What' the max passenger rated for that size boat ? Plan using it lightly, medium light of fully loaded ?
Happy Boating
rex979
It's rated for 8 passengers or 1150 lbs. It will probably be 2 persons 95% of the time with some light fishing gear. Maximum load it's rated for is 1800 lbs
Sea Rider
Test both props and their max wot rpm achieved as usually loaded, report after test if possile.. Personally would stay with the one that revs towards the max wot rpm range factory stated as like to count with superb fast hole shot while losing bit top end speed.
Happy Boating
Texasmark
The difference between the area of a circle of 14" vs 14.25 isn't much: In percentage is 3.5% . The difference between 19 and 21 is 10% without any regard for the actual physics of the effect of each on prop thrust in water which really is what interests you. Real answer to your question is how does each affect the performance of the prop.
Usually pusher props are larger in diameter and smaller in pitch to get the desired thrust......pushing heavy loads. Speed props are usually smaller in diameter and higher in pitch, made for pushing light loads fast. Then comes things like blade area (regardless of D and P dimensions), and "Rake"....bending the blades back from the root to accomplish desired "tuning" results in maybe bow or stern lift, and then cupping to hold better in shallow mounting installations, or hard turns at high speeds and all that engineering stuff prop designers take into consideration, like achris mentioned.
Props are gears with some slippage due to the medium...water vs wood or metal among other things. For which does what, less pitch, less distance travelled per revolution, less power required per revolution, less speed but more power available to keep the prop turning (developing thrust) under increased load....like water skiing.
rex979
Thanks for all the responses, I have tested the boat and it performs excellently with the 19 pitch prop for holeshot and when trimmed out will run 48 mph ( pitot, not GPS ) @ 5500 rpm
