JJBoatr
- Joined
- May 3, 2011
- 144
Mornin all,
Working on a 67' Creatliner Commodore Speedster with an Evinrude 25352A 25hp long shaft outboard.
My question is; what height should my transom be? When I first got the boat I didn't have a long shaft kit on my motor so I cut the transom down to 15". I have since acquired a long shaft motor and brought the transom back up to flat across the stern of the boat as it was before I cut it and it measured 21". This height put my water pick up dead even with and perhaps slightly above the keel and for fear of not getting water to the pick up I cut it back down to 19.5". Water pick up problem solved but now I get a rooster tail off the seem of the long shaft extension housing unless I trim all the way up to the 4th pin position. I also still catch an air bubble when turning at speed or when cruising over a 6" chop. Should I run the transom at its original 21" height? That would solve the rooster tail issue but I don't want to lose water pick up. Will the swell between the boat and motor come up enough to pick up water at that height? Thanks for the help.
