Hello I would like to build a small splashwell on my boat, its a 14' aluminum with a 20hp and a 15" transom. My transom is a little crowded where the engine sits, I plan on raising the engine 1-3inches. Iam just looking for a few ideas on how to build it and what height I should drill a hole for the water to exit and how to seal it against the boat and any other tips you might have. My intial plan is to build it out of 1/4inch plywood, paint it with some marine paint and use some sort of caulking to seal it all up against the transom and use a couple SS bolts to fasten it on either side to the hull and then drill a hole through the transom for the water to escape, Iam thinking the best place to drill the hole through the transom is about an inch below the metal cap over the transom. Pics explain 1000 words below....any suggestions, ideas or things not to do are very helpfull, and I have gone through countless posts on this subject which is where I got my intial idea. just starting my own which I will follow through with on the build.
