I just read a set of posts related to proper outboard motor hp on 14' al boat and just gotta say my two cents worth (maybe confession). I purchased a River City Marine model. It's rated for 30 hp, but I had an 1980 Mercury 40 hp from 16' tri-hull fiberglass boat I wrecked (another story about hitting a tree on the river bank) that I put on it. THat motor became not worth fixing, and replaced it with a used 1999 Force (by Mercury) 40 hp with hydraulic trim/tilt. It provided a little more ooomph with 14 pitch prop off the old 40. Yes, it's overpowered, but it's a heck of a ride! Stick steering for front seat driver keeps the bow down and tames porposing. Then I replaced the 6-gal tank with 12-gal tank behind the back seat. With battery under back seat and passenger on back seat, I can't slow to a stop too fast or turn corners to tight without water introducing itself over the transom or gunwale (did I spell that right?). I can't back down the ramp too fast either. Wife screams at me when turns are too tight, but man can it whip around a corner in short order! By the end of the day, she's got wet feet sloshing in a puddle of water.
I look forward to your reply posts. ...just don't tattle to USCG. BTW, my mechanic would not put the motor on the boat for obvious reasons.
