Hello I was hoping someone would be able to help me out with a boat I recently inherited from my father. I have been slowly in the process of restoring the boat and have issue with the boat performing bad at high speeds, you are going to have to bare with me I don't know all the technical terms so here goes my explanation of what happens.
The boat will nose up properly when you throttle up and come back down. After it comes back down and you begin to increase the throttle further the bow of the boat begins to sink to fair into the water the is hard to control and you get a lot of spray coming up the front sides of the boat. I have tried adjusting the tilt pin on the motor to see if this helps but it doesn't seem to matter what pin you put it in you get the same performance. In fact you get some cavatation in one of the pin positions.
This boat use to run fine with this motor on it without problems at higher speeds, then one day it just started. The transom was in bad shape when I got it but since then I have replaced it with 3x 3/4" plywood as you can see in the picture, thinking that this was the problem but no change (due note that it was run for years and years with a bad transom). I have uploaded several other pictures of the boat as well. Is it possible that the years it was ran with a weak transom has damaged it further then just replacing the plywood that was there.
Any thoughts would be appreciated.
