Re: 15 hp johnson rewind starter torque ????
Torque spec's for most fasteners are listed on a general spec sheet (page). Just look at size of the bolt,nut,etc. All fasterners of the same type size will have the same torque (generally). No manual will give you a specific value for every fastener. Unless a specific value is given, use the general spec. Now if you are refering to spring tension, I believe this is given in terms of # of turns or use enough turns to fully retract a specific length of rope. Bottom line, don't make a bigger deal of this job than it is. If you would like I will send you the OEM directions via email.
