15 hp johnson rewind starter torque ????
caldog101
I own a 1983 15 hp johnson my rope came off and just fixed but i can't find the tightening torque"ft/lbs" in my clymer manual can anybody help me ?
alcan
Re: 15 hp johnson rewind starter torque ????
Torque spec's for most fasteners are listed on a general spec sheet (page). Just look at size of the bolt,nut,etc. All fasterners of the same type size will have the same torque (generally). No manual will give you a specific value for every fastener. Unless a specific value is given, use the general spec. Now if you are refering to spring tension, I believe this is given in terms of # of turns or use enough turns to fully retract a specific length of rope. Bottom line, don't make a bigger deal of this job than it is. If you would like I will send you the OEM directions via email.
caldog101
Thanks alcan looked at the sheet for a 3/8 bolt and it is 18-20 ft. lbs so i will go with that
Paul Moir
Hold up - are you sure that's a 3/8ths bolt? That seems awfully big for holding a pull starter on. The 3/8ths should be the diameter of the threaded portion of the bolt, not the socket size.<br /><br />If this isn't a problem - please ignore. I just didn't want to see you strip out your threads torquing a 1/4" bolt to 20ft/lbs.
moderator1
Moving to Johnson/Evinrude questions.
