15 hp Rude 1979 Water pump kit
michiganmarty
Help! I went to my distant dealer for a water pump kit and the kit contained a small seal for the top of the pump to the drive-shaft. The question is, since the removed pump did not have one installed, is the seal neeeded?
OBJ
Re: 15 hp Rude 1979 Water pump kit
Marty....if there ain't one there, there should be. Are ya sure that the one that's supposed to be there ain't?
michiganmarty
Yes - I'm absolutely positive it wasn't there.<br />The seal insertion area of the pump has no witness marks of ever having one pressed in. <br />No, I didn't lose it. That would have been impossible, since I don't think you can even remove the seal once it is installed. <br /><br />There IS a witness mark on the driveshaft where there once was a seal riding on it and wore a definite groove. This motor has probably had several pumps installed, but apparently the last installation was incomplete.<br /><br />I DID install the seal on the new pump, and My-My-My, the pee hole squirts better than it ever did. Of course the previous performance may have been due to the poor job the previous owner did of installing the copper tube up at the base of the PowerHead. The hole in the bottom of the block was nearly plugged with the old rubber grommet/seal. <br /><br />That is probably why the previus owner removed the thermostat - overheating...and that is probably why the motor was completely wore out - forcing me to rebuild it to preserve the money I already had into it. <br />Yes completely wore out! rings, pistons, rods & wristpins, crankshaft, and had to machine the bores to .030 over.<br /><br />The pump seal question came up because I decided if I was going to spend all the cash and time to rebuild this thing it would be absolutely nuts to not replace the pump while I was at it...
michiganmarty
Oh, by the way - the service manual does not mention the seal...
