I picked up (literally, out of the garbage) a 2000 Johnson 15 the other day, and it has virtually no compression. The PO said it was running fine, made a 'pop' noise, and died. So far, I've pulled the head, expecting to see destruction, but everything looks perfect. The head gasket looks OK also, or at least not bad enough to lose all compression. What surprised me was to see a small hole in each cylinder above the ports on the exhaust side. It definitely belongs there; What is it's purpose? Could something have blown in there to take away the compression? I also have no spark, but that could be a safety switch or something that I haven't found yet. If I can't sort it out, I'll just part it out, but it's worth a shot to fix it.
