scout-j-m
- Joined
- Jul 31, 2009
- 642
I have a relatively new to me 1982 Evinrude 15HP, model E15RCNC. I bought it based off having good compression and that the seller ran it in a barrel at low speed on top of a good price. Since I have bought it, I have checked the impeller and LU oil and both are in good shape and the motor is cooling. I rechecked compression and got 110 psi on both cylinders. I installed a helicoil into the stripped recoil starter hole and now don?t have to use a rope on the flywheel. I checked spark and both are jumping a ?? air gap on my spark tester.
The first time I tried it out on the lake I was in a 1436 flatbottom. I had previously just ran an old Sportwin 9.5 hp and got a decent 16 mph out of it on the boat so figured this one would do much better. First blast off it took off with good power and immediately bogged down to just a few mph. Back home in the barrel I rechecked everything I did prior and after convincing myself it was good I gave it another lake test on my new 1648 Alumacraft flatbottom. Same bogging, lack of power, and slow speed/low rpms as before. FWIW the Sportwin did 15mph on this hull.
This time, I rebuilt the carb. The old one was clean but the needle was sticking some. Lake tested again and got the same results. This test though I tried pulling plug wires. Pulled one plug wire and ran the motor and it ran like when both were plugged in?so I thought it might have dropped a cylinder. But then flipped it and it still ran, just slightly worse. So both cylinders are firing.
On to working on it again in a barrel at home, I pull the plug wires while it?s running at a somewhat fast neutral idle and have the same results as on the water however I notice massive arcing from the disconnected coil to the block and other coil. It does this when either plug is disconnected. Is this a sure fire indicator the coils are bad? Or should that be expected when they have such a high charge and nowhere to dissipate the energy to?
I will add I have not installed new plugs yet. They are the correct ones though in that they are Champion QL77JC4. Neither looks totally fouled although one does have some white spots on it. I know I have compression, spark (at least to the plugs), and fuel (I?m confident in my carb rebuild as I was very thorough). In all of my tests I tried pumping the primer bulb but to no avail, gas was fresh and properly mixed, and vent cap open. Does this seem like fouled spark plugs? Or does the coil arcing I mentioned indicate something else? I am buying new plugs today and ordering new plug wires too. I?m looking for advice as to what the problem may be and what to try next if new plugs and wires don?t do the trick. I definitely don?t want to go throwing money at the ignition system until I know for sure what is at fault in it, if anything.
